Product filter
karpati
Product filter
Post by karpati » 16 Feb 2022, 19:26
Hello!
In the Catalog/Products list, if I search for something in the Label filter, the search engine searches only at the beginning of the text.
What is the easiest way to search in the middle of te text?
For example:
Keyword: "le12"
Label: Apple123
Re: Product filter
Post by aimeos » 17 Feb 2022, 16:37
You can configure the "Standard" index manager instead of the "Mysql" one. MySQL offers full text search which is prefix based like in almost every performant search engine. The "Standard" index manager uses a LIKE-based search which will be painfully slow for more than ~1000 products because it can't use any database index, so use with extreme care!
'mshop' => [
	'index' => [
		'manager' => [
			'name' => 'Standard'
karpati
Re: Product filter
Post by karpati » 17 Feb 2022, 20:23
Thanks for the reply.
I set up what you wrote, but the admin still doesn't search in the middle of the texts.
	'mshop' => [
            'index' => [
                    'manager' => [
                            'text' => [
            'price' => [
                'precision' => 0
Re: Product filter
Post by aimeos » 21 Feb 2022, 09:28
It must be:
'mshop' => [
	'index' => [
		'manager' => [
