category name in the catalog detail page
- GülsümAkça
is it possible to get the category id or category name in the catalog/detail/body-standard.php?
thank you
thank you
Re: category name in the catalog detail page
Yes, if you add this to the configuration documented here:
https://aimeos.org/docs/2021.x/config/c ... l/#domains
Then, you can use in your template:
'catalog' => [
'text',
<?= $this->detailProductItem->getCategoryItems()->getName()->first() =>
- GülsümAkça
is this working in 2020.x version?
- Screenshot_46.png (26.11 KiB) Viewed 19178 times
Sorry, the method is named "getCatalogItems()":
https://github.com/aimeos/aimeos-core/b ... hp#L27-L32
Fixed that in the initial reply.
- PedroLópezAndradas
How this works on 2022.x?
Category references move from mshop_catalog_list to mshop_product_list table and you can now use:
Make sure, the categories are fetched by the manager with the correct domains.
$product->getRefItems( 'catalog' );Professional support and custom implementation are available at Aimeos.com
This seems to be bugged when a product is added in several categories. The path fetched by $this->detailProductItem->getRefItems( 'catalog' ) is incorrect.
Also I see no way of getting the actual category the product was accessed through and translated labels of the categories.
I am now passing the categoryId the product was actually opened from to the detail view and am using it in my Decorator to work my way back through the category tree to get an actual, existing breadcrumb path and not just some random chaos. This was the only solution I could think of that fixes this problem.
$this->detailProductItem->getRefItems( 'catalog' )Only the catalog/stage component fetches the category path for creating the breadcrumb:
https://github.com/aimeos/ai-client-htm ... #L183-L240
