permissions and roles of users
ahmed31916
Post by ahmed31916 » 18 Apr 2022, 16:00
What is the page that controls the permissions and roles of users?
Re: permissions and roles of users
Post by aimeos » 19 Apr 2022, 06:28
It's done by configuration any you can find the default permissions for each panel here:
https://github.com/aimeos/ai-admin-jqad ... source.php
AhmadHelali
Post by AhmadHelali » 22 Feb 2023, 15:28
Where can I find the roles and permissions in aimeo's Standalone application?
Post by aimeos » 22 Feb 2023, 15:36
You should overwrite it in your own extension or the ./config/shop.php file?
The referenced file is located in the ./vendor/ folder but you can't change it there because it will get overwritten each time you run "composer update".
