Tilde in Route aimeos_shop_tree
godadada@yahoo.com
I have aimeos 2021.10/ubuntu complains about
"Missing required parameter for [Route: aimeos_shop_tree] [URI: shop/{site}/{f_name}~{f_catid}] [Missing parameter: f_name]."
the route is defined as following. i suspect something to do with tilde usage or miss-use. It is used as delimiter or bit negation. please enlighten if the following two places are all used correctly. also attached debug trace results.
Route::match( array( 'GET', 'POST' ), '{f_name}~{f_catid}', array(
'as' => 'aimeos_shop_tree',
'uses' => 'Aimeos\Shop\Controller\CatalogController@treeAction'
) )->where( ['site' => '[A-Za-z0-9\.\-]+', 'f_name' => '[^~]*'] );
- route.png (131 KiB) Viewed 3806 times
- missing f_name.png (219.15 KiB) Viewed 3806 times
godadada@yahoo.com
Re: Tilde in Route aimeos_shop_tree
I understand for the REG pattern matching for '[^~]*' but have no clue what tilde is doing in this '{f_name}~{f_catid}'.
Any input is appreciated.
The tilde is only a separator between two variables like any other character, e.g. "/".
Laravel complains that no value for f_name (even not an empty one) is passed when the URL should be generated. To fix it, check where in the template the URL is generated and add a this to the parameters passed to the method generating the URL:
"f_name" => ''Professional support and custom implementation are available at Aimeos.com
godadada@yahoo.com
thanks for the tip. the DB is corrupted during dev. It is okay now after refreshing the DB.
