Aimeos create extension " Could not find a matching version of package aimeos-extensions/new-test. Check the package sp"
krzysiekp
Post by krzysiekp » 09 May 2022, 08:04
I try install new theme:
composer req aimeos-extensions/new-test
I always receive error:
 [InvalidArgumentException]
  Could not find a matching version of package aimeos-extensions/new-test. Check the package spelling, your version constraint and that the package is available in a stability which matches your minimum-stability (dev).
cyberdev
Re: Aimeos create extension " Could not find a matching version of package aimeos-extensions/new-test. Check the package
Post by cyberdev » 09 May 2022, 10:46
correct the version in Extension composer..
Post by aimeos » 09 May 2022, 13:45
Please read this section about how to install extensions:
https://aimeos.org/docs/latest/laravel/ ... -extension
Like @cyberdev said, you also need to generate the correct version of the extension for you Aimeos Laravel extension (both 2021.x or both 2022.x, depending on what's installed).
