Can I separate the Merchant panel from the admin panel
ahmed31916
Post by ahmed31916 » 11 May 2022, 19:45
How can I separate the Merchant admin interface from the super admin interface?
(theme and template)
Re: Can I separate the Merchant panel from the admin panel
Post by aimeos » 13 May 2022, 06:29
You mean building a separate admin interface for merchants in the frontend?
If yes, it's possible but you have to implement the code for fetching and storing the data you want to manager yourself. The profile page can be extended for managing products if you implement your own components for that:
https://aimeos.org/docs/latest/frontend ... omponents/
