How to extend a mshop_order_base table
- IvanIgniter
I am using laravel 6.x, PHP 7.4, Docker desktop/Ubuntu and the Aimeos 2021 (aimeos-laravel: 2021.10.4 / aimeos-core: 2021.10.13)
I have implemented different decorators like customers, product, orders but this time I want to create a decorator for sub-item for mshop_order_base table. From the documentation I can't find any examples. Kindly help me how to implement it or give me a link.
Thank you
Thank you
Re: How to extend a mshop_order_base table
It's the same like for the domain managers, only the configuration contains the type of the sub-manager:
https://github.com/aimeos/aimeos-core/b ... p#L78-L105
- IvanIgniter
I am not sure what you mean only the configuration contains the type of the sub-manager and based on the link.
This how I understand and did it but after php artisan aimeos:setup. No additional field was added in mshop_order_base table.
Please guide how it is done to make it right.
I also tried this way And this and moved the Myproject.php file to
ext\ai-admin-jqadm\lib\custom\src\MShop\Order\Manager\Base\Decorator\Myproject.php
- IvanIgniter
Waiting for a respond.. Please help what is the solution?
- IvanIgniter
Could anybody help or suggest what to do if they encounter the same issue?
- IvanIgniter
I have figured it out how to add the new columns to mshop_order_base but I couldn't display those added new fields.
Please advise what is the correct configuration to show it in aimeos admin order list page.
Your schema file is now correct (order.php) but your decorator configuration must be:
See: https://aimeos.org/docs/2022.x/config/m ... atorslocal
'mshop' => [
'order' => [
'manager' => [
'base' => [
'decorators' => [
'local' => [
'MyProject'
- IvanIgniter
Thank you..
'order' => [
'manager' => [
'base' => [
'decorators' => [
'local' => [
'Myproject'
'decorators' => [
'local' => ['Myproject']
Works for me.
The second mistake was the Decorator/Myproject should be mordba.fieldname not mordbase.fieldname
'order' => [
'manager' => [
'base' => [
'decorators' => [
'local' => [
'Myproject'
'decorators' => [
Works for me.
- IvanIgniter
Can I have a last one more question using a decorator.
I was able to display now what records are stored in the db but storing into that extra fields along with existing fields is not working.
Why is the comment field was the only one stored in the db and the new field last_name did not?
I was tracing the whole codes as will as the aimeos core to make it right but I can't figure it out.
- 4a.jpg (90.38 KiB) Viewed 18415 times
- 4.jpg (156.23 KiB) Viewed 18415 times
You must hand over "last_name", not "order.base.last_name". The key is exactly the same as you use in your decorator.
