How to use translate function in laravel blade?
cyberdev
Re: How to use translate function in laravel blade?
Post by cyberdev » 14 Jun 2022, 12:48
Just use the aimeos helper function, its is explained in aimeos doc
https://aimeos.org/docs/latest/laravel/ ... -templates
Post by aimeos » 14 Jun 2022, 19:54
In Blade templates, you can use the standard Laravel translation:
https://laravel.com/docs/9.x/localization
