getting problem in csv import of products and categories
VirtualSpy
Post by VirtualSpy » 05 Jul 2022, 13:36
can i remove this mail configuration error and also getting some error in log ........please help me to solve my problems
Aimeos Version 2021.10.5, PHP Version php-7.4.19-Win32-vc15-x64
Screenshot (13).png (176.28 KiB) Viewed 7338 times
Re: getting problem in csv import of products and categories
Post by aimeos » 06 Jul 2022, 07:43
Click on the first error message in the Log panel to get more details and post them.
Your second screenshot shows that the e-mail couldn't be sent due to missing credentials. Add a valid mail server configuration to your .env file.
VirtualSpy
Post by VirtualSpy » 06 Jul 2022, 08:29
2022-07-06 06:17:49 import/csv/product 3
Product import error: mkdir(): File exists
#0 [internal function]: Illuminate\Foundation\Bootstrap\HandleExceptions->handleError(2, 'mkdir(): File e...', 'D:\\laragon\\www\\...', 51, Array)
#1 D:\laragon\www\cliqnshop.com\vendor\aimeos\aimeos-core\lib\mwlib\src\MW\Container\Directory.php(51): mkdir('storage\\tmp\\imp...', 493, true)
#2 D:\laragon\www\cliqnshop.com\vendor\aimeos\aimeos-core\lib\mwlib\src\MW\Container\Factory.php(46): Aimeos\MW\Container\Directory->__construct('storage\\tmp\\imp...', 'CSV', Array)
#3 D:\laragon\www\cliqnshop.com\vendor\aimeos\ai-controller-jobs\controller\jobs\src\Controller\Jobs\Product\Import\Csv\Standard.php(527): Aimeos\MW\Container\Factory::getContainer('storage\\tmp\\imp...', 'Directory', 'CSV', Array)
#4 D:\laragon\www\cliqnshop.com\vendor\aimeos\ai-controller-jobs\controller\jobs\src\Controller\Jobs\Product\Import\Csv\Standard.php(329): Aimeos\Controller\Jobs\Product\Import\Csv\Standard->getContainer()
#5 D:\laragon\www\cliqnshop.com\vendor\aimeos\aimeos-laravel\src\Aimeos\Shop\Command\JobsCommand.php(54): Aimeos\Controller\Jobs\Product\Import\Csv\Standard->run()
#6 [internal function]: Aimeos\Shop\Command\JobsCommand->Aimeos\Shop\Command\closure(Object(Aimeos\MShop\Context\Item\Standard), Object(Aimeos\Bootstrap), 'product/import/...')
#7 D:\laragon\www\cliqnshop.com\vendor\aimeos\aimeos-core\lib\mwlib\src\MW\Process\Decorator\Check.php(63): call_user_func_array(Object(Closure), Array)
#8 D:\laragon\www\cliqnshop.com\vendor\aimeos\aimeos-laravel\src\Aimeos\Shop\Command\JobsCommand.php(63): Aimeos\MW\Process\Decorator\Check->start(Object(Closure), Array, false)
#9 [internal function]: Aimeos\Shop\Command\JobsCommand->Aimeos\Shop\Command\closure(Object(Aimeos\MShop\Context\Item\Standard), Object(Aimeos\Bootstrap))
#10 D:\laragon\www\cliqnshop.com\vendor\aimeos\aimeos-core\lib\mwlib\src\MW\Process\Decorator\Check.php(63): call_user_func_array(Object(Closure), Array)
#11 D:\laragon\www\cliqnshop.com\vendor\aimeos\aimeos-laravel\src\Aimeos\Shop\Command\AbstractCommand.php(67): Aimeos\MW\Process\Decorator\Check->start(Object(Closure), Array, false)
#12 D:\laragon\www\cliqnshop.com\vendor\aimeos\aimeos-laravel\src\Aimeos\Shop\Command\JobsCommand.php(69): Aimeos\Shop\Command\AbstractCommand->exec(Object(Aimeos\MShop\Context\Item\Standard), Object(Closure), NULL)
#13 D:\laragon\www\cliqnshop.com\vendor\laravel\framework\src\Illuminate\Container\BoundMethod.php(36): Aimeos\Shop\Command\JobsCommand->handle()
#14 D:\laragon\www\cliqnshop.com\vendor\laravel\framework\src\Illuminate\Container\Util.php(40): Illuminate\Container\BoundMethod::Illuminate\Container\closure()
#15 D:\laragon\www\cliqnshop.com\vendor\laravel\framework\src\Illuminate\Container\BoundMethod.php(93): Illuminate\Container\Util::unwrapIfClosure(Object(Closure))
#16 D:\laragon\www\cliqnshop.com\vendor\laravel\framework\src\Illuminate\Container\BoundMethod.php(37): Illuminate\Container\BoundMethod::callBoundMethod(Object(Illuminate\Foundation\Application), Array, Object(Closure))
#17 D:\laragon\www\cliqnshop.com\vendor\laravel\framework\src\Illuminate\Container\Container.php(653): Illuminate\Container\BoundMethod::call(Object(Illuminate\Foundation\Application), Array, Array, NULL)
#18 D:\laragon\www\cliqnshop.com\vendor\laravel\framework\src\Illuminate\Console\Command.php(136): Illuminate\Container\Container->call(Array)
#19 D:\laragon\www\cliqnshop.com\vendor\symfony\console\Command\Command.php(298): Illuminate\Console\Command->execute(Object(Symfony\Component\Console\Input\ArgvInput), Object(Illuminate\Console\OutputStyle))
#20 D:\laragon\www\cliqnshop.com\vendor\laravel\framework\src\Illuminate\Console\Command.php(121): Symfony\Component\Console\Command\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Illuminate\Console\OutputStyle))
#21 D:\laragon\www\cliqnshop.com\vendor\symfony\console\Application.php(1024): Illuminate\Console\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#22 D:\laragon\www\cliqnshop.com\vendor\symfony\console\Application.php(299): Symfony\Component\Console\Application->doRunCommand(Object(Aimeos\Shop\Command\JobsCommand), Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#23 D:\laragon\www\cliqnshop.com\vendor\symfony\console\Application.php(171): Symfony\Component\Console\Application->doRun(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#24 D:\laragon\www\cliqnshop.com\vendor\laravel\framework\src\Illuminate\Console\Application.php(94): Symfony\Component\Console\Application->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#25 D:\laragon\www\cliqnshop.com\vendor\laravel\framework\src\Illuminate\Foundation\Console\Kernel.php(129): Illuminate\Console\Application->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#26 D:\laragon\www\cliqnshop.com\artisan(37): Illuminate\Foundation\Console\Kernel->handle(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#27 main
Post by aimeos » 06 Jul 2022, 08:34
Please check your CSV import configuration, there seems to be something misconfigured.
VirtualSpy
Post by VirtualSpy » 08 Jul 2022, 08:29
Thank You so much for helping me! and i hope in future too you will help to me.
