sort products by id
- ahmed31916
- Advanced
sort products by id
Hello Aimeos,
Why the sort method doesn't work here?
$manager = \Aimeos\Controller\Frontend::create( $context, 'product' )->uses( $domains );
$feature_cars = $manager->search()->slice(0,5)->sort('-', 'product.id');Re: sort products by id
The sort() method accepts only a single parameter, not two:
See here: https://github.com/aimeos/ai-controller ... #L187-L194
$cntl = \Aimeos\Controller\Frontend::create( $context, 'product' )->uses( $domains );
$cntl->slice(0,5)->order('-product.id')->search();
- ahmed31916
- Advanced
I got this error:
https://flareapp.io/share/LPlLk8DP#F66
Call to a member function getType() on nullRe: sort products by id
Please create a new topic for questions not related to the existing topic.
- ahmed31916
- Advanced
it is related to the same topic, when I apply this code I got the previous error:aimeos wrote: 13 Jul 2022, 06:54 Please create a new topic for questions not related to the existing topic.
$cntl->slice(0,5)->sort('-product.id')->search();
But nevertheless, another problem in another file and not related to your initial question.
The problem is that you use:
This will error if there's not price available and to circumvent the error, you can use this instead:
$prices->first()->getType()Code: Select all
$prices->getType()->first()Professional support and custom implementation are available at Aimeos.com
