Some issues in the theme
- VirtualSpy
- Advanced
Laravel version 9.22.1 , Aimeos version 2022.07.2 and PHP version 8.1.3 (Win)
When i am using Laravel theme 2022.x extension , shop is not looking good......please check and please fix this
Re: Some issues in the theme
Please provide more information and screenshots.
- VirtualSpy
- Advanced
please see difference in screenshot
- issue.jpg (42.91 KiB) Viewed 7907 times
pamirsawar
I had the similar issue. cms-page.css and cms-page.js files were missing in the public folder.
these files can be found in \vendor\aimeos\ai-cms-grapesjs\themes\client\html\default\
for now I copied and pasted them into my theme folder in public directory. But I believe it's better if aimeos did that with composer vendor:publish command
The included CSS/JS files in the generated extensions have been updated and the files from the ai-cms-grapesjs package added.
- VirtualSpy
- Advanced
Thank you so muchaimeos wrote: 22 Aug 2022, 10:51 The included CSS/JS files in the generated extensions have been updated and the files from the ai-cms-grapesjs package added.
That has nothing to do with the theme files
- VirtualSpy
- Advanced
it is working ....i did not clear my cache.....
