Where and how change controller logic of modules?
oliwin4
Post by oliwin4 » 29 Aug 2022, 21:21
Where and how to change logic of modules (controllers)? For example catalog/lists?
I tried to create an extentions then I copied the exist core controller into a new extention directory:
\sumka\myshop\packages\sumka\src\CatalogController.php
Inside method of controller I have added the following:
	public function homeAction()
		echo "test"
The I reset the cache views. But there is not result
Re: Where and how change controller logic of modules?
Post by aimeos » 31 Aug 2022, 07:12
You can't overwrite classes in Laravel that way. If you implement a new controller like you did, you can add a new route in your ./routes/web.php or replace an Aimeos route with your new controller if you disable the Aimeos route first:
https://github.com/aimeos/aimeos-larave ... #L257-L267
