Why the icons doesn't displayed
- ahmed31916
- Advanced
Why the icons doesn't displayed?
- Screenshot 2022-09-05 095027.png (18.85 KiB) Viewed 9717 times
Re: Why the icons doesn't displayed
FontAwesome changed their CSS. Please update to the latest Aimeos packages.
- ahmed31916
- Advanced
I updated aimeos package to the last version and the icons that were not visible appeared now and everything ok, but the pagination buttons and the logout button remain.
- Screenshot 2022-09-07 123303.png (67.81 KiB) Viewed 9680 times
Did you overwrite some templates? When installing the latest version from scratch, all icons are there.
- ahmed31916
- Advanced
I tried to overwrite on the template that not related to CMS (product item template).
I installed the last version and the logout icon appeared, but pagination icons doesn't.
Did you copy the JS code or don't use aimeos/ai-admin-jqadm:2022.07.4 or later?
The pagination icons have been fixed a while ago with that commit:
https://github.com/aimeos/ai-admin-jqad ... 67526f99ca
- ahmed31916
- Advanced
I found the problem, I overwrite on some templates. So I had to update the font awesome on the templates too.
