Integrate TailwindCSS (Suggestion)
peter69
Post by peter69 » 20 Sep 2022, 04:31
Hello everyone!
I am continuing with the development of a store, and in the theme/package I have created I am using TailwindCSS and I am removing the default Laravel Aimeos CSS.
So in the frontend, the final size of the CSS files is minimal.
TailwindCSS is a great tool that I have used in other Laravel and Vue.js projects. I think it would be great to use this tool in Laravel Aimeos, it will certainly give it a more current and modern design.
This is a suggestion, I will be happy to hear your opinions,
Regards!
Re: Integrate TailwindCSS (Suggestion)
Post by aimeos » 20 Sep 2022, 06:17
Tailwind is not suitable for building CSS based themes because all styles are added as CSS classes to the HTML templates. Thus, you would need to overwrite the Tailwind CSS classes with "!important" constantly.
peter69
Post by peter69 » 20 Sep 2022, 06:40
Maybe it would only be feasible if from laravel aimeos core you use tailwindcss instead of .css files. But I guess at this stage of the project it's not a recommendable thing to do.
