Replace translation not working
kdim95
Post by kdim95 » 17 Oct 2022, 08:36
Laravel framework version: 9.26.1
Aimeos Laravel version: * 2022.07.2
PHP Version: 8.1.9
Environment: Linux
I'm following the documentation for replacing translations here:
https://aimeos.org/docs/2022.x/develope ... anslations
I am attempting to replace the translations found in:
vendor/aimeos/aimeos-core/i18n/mshop/code/bg.po
I have placed the copied and modified .po file in my extension like so:
packages/my-extension/i18n/mshop/code/bg.po
And I have executed the required command in the directory:
msgfmt --statistics -c -o bg bg.po
This created a new "bg" file in the same directory.
But it's not working, apparently it's not using the new "bg" file I've generated.
Re: Replace translation not working
Post by aimeos » 18 Oct 2022, 06:26
The translations must be directly in the i18n directory of your extension (all in one file).
Where the translations are looked up is defined in the "i18n" section of the manifest.php file in your extension.
kdim95
Post by kdim95 » 18 Oct 2022, 08:14
Thank you, it works now
