Embed image into email template
kartikbhat
Post by kartikbhat » 27 Oct 2022, 11:00
How to use embedding images into the email template ? from this document I got that it will return Content Id of the image to the img tag,
I am not getting how to use this eith in Standard.php or body-standard.php of email template
$msg or $content are not accessable inside body-standard.php
Help me to add it correctly
TIA :)
Re: Embed image into email template
Post by aimeos » 28 Oct 2022, 09:48
This is correct but you need to make sure that the image file is available in the same directory as the template so it's found.
kartikbhat
Post by kartikbhat » 29 Oct 2022, 15:29
I have a file called logo.png present in public folder of laravel project, then how can I bring this logo as an embedded image in my email template ?
by using above syntax how I make it possible?
need to add it in Standard.php or html-body-standard.php ?
Can you provide me an example or more detail on usage of this? please
TIA :)
