how to create theme color scheme configuration settings in admin side
mahammadareef
Post by mahammadareef » 29 Oct 2022, 07:04
in aimeos admin side default theme color scheme settings are available like this image attached, I want to create color settings for my custom theme how to do this?
Re: how to create theme color scheme configuration settings in admin side
Post by aimeos » 29 Oct 2022, 09:18
1.) Define your CSS variables in your app.css file of your theme:
https://github.com/aimeos/ai-client-htm ... ss#L46-L61
2.) Configure your theme name and the default values like in the CSS variables:
https://github.com/aimeos/ai-client-htm ... #L282-L301
3.) Change the used theme name in the Settings panel of the admin backend
antoniosequeira66
Post by antoniosequeira66 » 13 Dec 2022, 16:49
Hello, I've followed all procedures to create a new theme as described here
https://aimeos.org/docs/latest/frontend ... -extension
Also clean caches
php artisan aimeos:clear
php artisan cache:clear
using "composer update" theme folder is copied to
........../public/vendor/shop/themes/<mytheme>
another try, I replace this with symbolic link to
..../packages/<extension>/themes/client/html/<theme>
but both cases, my theme is not available to select under admin settings page.
The only option is Default
What I'm missing here?
thanks in advance
Post by aimeos » 15 Dec 2022, 07:37
Did you create a "Laravel theme" extension or a base Aimeos extension?
Only "Laravel theme" extensions can be selected in the backend.
