Fixed country only for delivery
YnievesPuntoNet
Post by YnievesPuntoNet » 04 Nov 2022, 19:02
I try limit the country options (and state) for delivery. But dont work.
            'checkout' => [
                'standard' => [
                    'address' => [
                        'billing' => [
                        'delivery' => [
                        'countries' => ['XX'],
                        'states' => [
                            'XX' => [
                                'AA' => 'Aaaaaa',
                                'ZZ' => 'Zzzzzzz',
but work for billing and delivery. If I put this code inside delivery or billing section, not make any changes in the form
Thanks all
Re: Fixed country only for delivery
Post by aimeos » 06 Nov 2022, 19:38
Seems to be a mistake in the docs because the country and state list is retrieved from "common/countries" and "common/states" config keys for a while now:
https://github.com/aimeos/ai-client-htm ... #L262-L315
YnievesPuntoNet
Post by YnievesPuntoNet » 08 Nov 2022, 19:30
Is possible restrict only the country and the state only for Delivery, not for Billing?
Post by aimeos » 10 Nov 2022, 06:37
Not by default. You have to create a decorator for the checkout/standard/address/delivery subpart which overwrites the addressCountries view variable in its data() method:
https://aimeos.org/docs/latest/frontend ... omponents/
Something like:
public function data( \Aimeos\Base\View\Iface $view, array &$tags = [], string &$expire = null ) : \Aimeos\Base\View\Iface
	$view = parent::data( $view, $tags, $expire );
	$view->addressCountries = [...];
	return $view;
Decorator configuration would be:
client/html/checkout/standard/address/delivery/decorators/global = ['Mydecorator']
