Unknown database type enum requested
Hello everyone!
Ubuntu 20.04
PHP 8.1
aimeos/aimeos-laravel: "~2022.10"
Facing this porblem during: "php artisan aimeos:setup --option=setup/default/demo:1" :
Initializing or updating the Aimeos database tables for site "default"
Migrating: vendor/aimeos/aimeos-core/setup/TypesMigrateColumns.php
Doctrine\DBAL\Exception
Unknown database type enum requested, Doctrine\DBAL\Platforms\MySQL80Platform may not support it.
at vendor/doctrine/dbal/src/Platforms/AbstractPlatform.php:441
437▕
438▕ $dbType = strtolower($dbType);
439▕
440▕ if (! isset($this->doctrineTypeMapping[$dbType])) {
➜ 441▕ throw new Exception(
442▕ 'Unknown database type ' . $dbType . ' requested, ' . static::class . ' may not support it.',
443▕ );
444▕ }
445▕
+30 vendor frames
31 artisan:37
Illuminate\Foundation\Console\Kernel::handle()
Log:
[2022-12-01 11:33:35] local.ERROR: Unknown database type enum requested, Doctrine\DBAL\Platforms\MySQL80Platform may not support it. {"exception":"[object] (Doctrine\\DBAL\\Exception(code: 0): Unknown database type enum requested, Doctr>
[stacktrace]
#0 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/doctrine/dbal/src/Schema/MySQLSchemaManager.php(186): Doctrine\\DBAL\\Platforms\\AbstractPlatform->getDoctrineTypeMapping()
#1 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/doctrine/dbal/src/Schema/AbstractSchemaManager.php(1408): Doctrine\\DBAL\\Schema\\MySQLSchemaManager->_getPortableTableColumnDefinition()
#2 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/doctrine/dbal/src/Schema/AbstractSchemaManager.php(423): Doctrine\\DBAL\\Schema\\AbstractSchemaManager->_getPortableTableColumnList()
#3 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/doctrine/dbal/src/Schema/MySQLSchemaManager.php(66): Doctrine\\DBAL\\Schema\\AbstractSchemaManager->doListTables()
#4 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/doctrine/dbal/src/Schema/AbstractSchemaManager.php(1651): Doctrine\\DBAL\\Schema\\MySQLSchemaManager->listTables()
#5 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/aimeos/upscheme/src/Schema/DB.php(838): Doctrine\\DBAL\\Schema\\AbstractSchemaManager->createSchema()
#6 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/aimeos/upscheme/src/Schema/DB.php(54): Aimeos\\Upscheme\\Schema\\DB->setup()
#7 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/aimeos/upscheme/src/Up.php(110): Aimeos\\Upscheme\\Schema\\DB->__construct()
#8 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/aimeos/upscheme/src/Task/Base.php(87): Aimeos\\Upscheme\\Up->db()
#9 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/aimeos/aimeos-core/setup/TypesMigrateColumns.php(147): Aimeos\\Upscheme\\Task\\Base->db()
#10 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/aimeos/aimeos-core/setup/TypesMigrateColumns.php(122): Aimeos\\Upscheme\\Task\\TypesMigrateColumns->addColumn()
#11 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/aimeos/upscheme/src/Up.php(324): Aimeos\\Upscheme\\Task\\TypesMigrateColumns->up()
#12 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/aimeos/upscheme/src/Up.php(311): Aimeos\\Upscheme\\Up->runTasks()
#13 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/aimeos/upscheme/src/Up.php(311): Aimeos\\Upscheme\\Up->runTasks()
#14 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/aimeos/upscheme/src/Up.php(170): Aimeos\\Upscheme\\Up->runTasks()
#15 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/aimeos/aimeos-core/Setup.php(84): Aimeos\\Upscheme\\Up->up()
#16 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Command/SetupCommand.php(69): Aimeos\\Setup->up()
#17 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): Aimeos\\Shop\\Command\\SetupCommand->handle()
#18 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/laravel/framework/src/Illuminate/Container/Util.php(41): Illuminate\\Container\\BoundMethod::Illuminate\\Container\\{closure}()
#19 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\\Container\\Util::unwrapIfClosure()
#20 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\\Container\\BoundMethod::callBoundMethod()
#21 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/laravel/framework/src/Illuminate/Container/Container.php(651): Illuminate\\Container\\BoundMethod::call()
#22 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/laravel/framework/src/Illuminate/Console/Command.php(182): Illuminate\\Container\\Container->call()
#23 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/symfony/console/Command/Command.php(312): Illuminate\\Console\\Command->execute()
#24 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/laravel/framework/src/Illuminate/Console/Command.php(152): Symfony\\Component\\Console\\Command\\Command->run()
#25 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/symfony/console/Application.php(1020): Illuminate\\Console\\Command->run()
#26 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/symfony/console/Application.php(312): Symfony\\Component\\Console\\Application->doRunCommand()
#27 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/symfony/console/Application.php(168): Symfony\\Component\\Console\\Application->doRun()
#28 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/laravel/framework/src/Illuminate/Console/Application.php(102): Symfony\\Component\\Console\\Application->run()
#29 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(155): Illuminate\\Console\\Application->run()
#30 /var/www/tatmedia/devshop.tatmedia.ru/releases/5/artisan(37): Illuminate\\Foundation\\Console\\Kernel->handle()
#31 {main}
How can I fix it?
Ubuntu 20.04
PHP 8.1
437▕
439▕
443▕ );
444▕ }
445▕
+30 vendor frames
31 artisan:37
Log:
[stacktrace]
#31 {main}
How can I fix it?
Re: Unknown database type enum requested
We haven't seen that before but maybe you are using an ENUM column type in your existing Laravel "users" table which Doctrine can't handle?
Thank U!aimeos wrote: 01 Dec 2022, 12:02 We haven't seen that before but maybe you are using an ENUM column type in your existing Laravel "users" table which Doctrine can't handle?
I'll have a look-see.
I've no ENUM column type in my existing Laravel "users" table(aimeos wrote: 01 Dec 2022, 12:02 We haven't seen that before but maybe you are using an ENUM column type in your existing Laravel "users" table which Doctrine can't handle?
Is there an ENUM column anywhere else in your database tables?
Yes, I have one.
Why Aimeos installation command changes it?
Сan I somehow avoid it?
- unnamed1.png (103.48 KiB) Viewed 12697 times
It's not Aimeos, Doctrine DBAL (which we use for schema updates) parses the complete database schema and don't understand the ENUM data type:
https://www.doctrine-project.org/projec ... html#types
