How to set price of attributes in basket base of supplier/sites
developer
Post by developer » 01 Dec 2022, 17:37
How to set price of attributes in basket base of supplier/sites?
I have set price of attrbutes different for each supplie/site, But once i try to add to cart product its take default site attribute price on basket.
How I can add attributes price base on supplier/site proudct.
I have also try with siteid on attributes hiddent set on product details page.
  <input type="hidden" name="<?= $enc->attr($this->formparam(['b_prod', 0, 'siteid'])) ?>" value="<?= $enc->attr($this->detailProductItem->getSiteId()) ?>">
                                    <input type="hidden" name="b_siteid" value="<?= $enc->attr($this->detailProductItem->getSiteId()) ?>">
Can anyone help me for the same?
Thanks in Advance
Re: How to set price of attributes in basket base of supplier/sites
Post by aimeos » 02 Dec 2022, 08:43
Can you please tell us more about your setup?
developer
Post by developer » 03 Dec 2022, 16:08
Here I have added my composer.json file code for check version of aimeos and other details.
"php": "^7.3||^8.0",
        "composer-runtime-api": "^2.1",
        "aimeos/ai-cache": "~2021.10",
        "aimeos/ai-client-html": "2021.10.x-dev",
        "aimeos/ai-controller-frontend": "2021.10.x-dev",
        "aimeos/ai-controller-jobs": "2021.10.x-dev",
        "aimeos/ai-filesystem": "~2021.10",
        "aimeos/ai-payments": "2021.10.x-dev",
        "aimeos/aimeos-core": "2021.10.x-dev",
        "aimeos/aimeos-laravel": "2021.10.x-dev",
        "aimeoscom/ai-sites": "2021.10.x-dev",
        "aimeoscom/ai-stripe-marketplace": "2021.10.x-dev",
But I have stuck here, because basket product get the default first price of attribute. I want price of attributes as supplier/site set.
Might be some where this section where i need to update but its on vendor part, any other way?
\vendor\aimeos\ai-controller-frontend\controller\frontend\src\Controller\Frontend\Basket\Standard.php
public function addProduct( \Aimeos\MShop\Product\Item\Iface $product,
		float $quantity = 1, array $variant = [], array $config = [], array $custom = [],
		string $stocktype = 'default', string $supplierid = null, string $siteid = null ) : Iface
		$quantity = $this->call( 'checkQuantity', $product, $quantity );
		$this->call( 'checkAttributes', [$product], 'custom', array_keys( $custom ) );
		$this->call( 'checkAttributes', [$product], 'config', array_keys( $config ) );
		$prices = $product->getRefItems( 'price', 'default', 'default' );
		$hidden = $product->getRefItems( 'attribute', null, 'hidden' );
		$custAttr = $this->call( 'getOrderProductAttributes', 'custom', array_keys( $custom ), $custom );
		$confAttr = $this->call( 'getOrderProductAttributes', 'config', array_keys( $config ), [], $config );
		$hideAttr = $this->call( 'getOrderProductAttributes', 'hidden', $hidden->keys()->toArray() );
		$orderBaseProductItem = \Aimeos\MShop::create( $this->getContext(), 'order/base/product' )->create()
			->copyFrom( $product )->setQuantity( $quantity )->setStockType( $stocktype )
			->setAttributeItems( array_merge( $custAttr, $confAttr, $hideAttr ) );
		$orderBaseProductItem = $orderBaseProductItem
			->setPrice( $this->call( 'calcPrice', $orderBaseProductItem, $prices, $quantity ) );
		if( $siteid ) {
			$orderBaseProductItem->setSiteId( $siteid );
		if( $supplierid )
			$name = \Aimeos\MShop::create( $this->getContext(), 'supplier' )->get( $supplierid, ['text'] )->getName();
			$orderBaseProductItem->setSupplierId( $supplierid )->setSupplierName( $name );
		$this->baskets[$this->type] = $this->get()->addProduct( $orderBaseProductItem );
		return $this->save();
\controller\frontend\src\Controller\Frontend\Basket\Base.php
protected function getOrderProductAttributes( string $type, array $ids, array $values = [], array $quantities = [] )
		$list = [];
		if( !empty( $ids ) )
			$manager = \Aimeos\MShop::create( $this->getContext(), 'order/base/product/attribute' );
			foreach( $this->getAttributes( $ids ) as $id => $attrItem )
				$list[] = $manager->create()->copyFrom( $attrItem )->setType( $type )
					->setValue( isset( $values[$id] ) ? $values[$id] : $attrItem->getCode() )
					->setQuantity( isset( $quantities[$id] ) ? $quantities[$id] : 1 );
		return $list;
Post by aimeos » 04 Dec 2022, 10:59
The problem that in marketplace setups the lowest price of all vendors is used instead of the vendor attribute price when more then one vendor uses the same attribute maybe could be solved here:
https://github.com/aimeos/ai-controller ... hp#L56-L66
If we change that to:
$siteId = $this->context()->locale()->getSiteId();
foreach( $orderAttributes as $orderAttrItem )
	if( !( $attrItem = $attrItems->get( $orderAttrItem->getAttributeId() ) ) ) {
		continue;
	$prices = $attrItem->getRefItems( 'price', 'default', 'default' )->filter( function( $price ) use ( $orderProduct, $siteId ) {
		return $price->getSiteId() === $orderProduct->getSiteId() || $price->getSiteId() === $siteId;
	if( !$prices->isEmpty() )
		$attrPrice = $priceManager->getLowestPrice( $prices, $orderAttrItem->getQuantity() );
		$price = $price->addItem( clone $attrPrice, $orderAttrItem->getQuantity() );
		$orderAttrItem->setPrice( $attrPrice->addItem( $attrPrice, $orderAttrItem->getQuantity() - 1 )->getValue() );
Can you check and make a PR if it works?
developer
Post by developer » 05 Dec 2022, 17:24
Thanks for your support.
It working perfectly!
