How to add options to grapesjs
PedroLópezAndradas
Post by PedroLópezAndradas » 20 Jan 2023, 09:14
I am trying to personalize a bit texts on CMS (grapesjs).
I have seen that there are no text align options, for example.
Is there a way to add some basic modules (like Richtext) or extensions (like artf/grapesjs-lory-slider)?
Maybe this can be managed easily, but I couldn't find it on documentation.
Thanks!
Re: How to add options to grapesjs
Post by aimeos » 20 Jan 2023, 16:23
The GrapesJS configuration is available here and you can overwrite or all own config/code in your own extension JS file:
https://github.com/aimeos/ai-cms-grapes ... s#L71-L789
