Sorting products in cms cataloglist
PedroLópezAndradas
Post by PedroLópezAndradas » 09 Mar 2023, 21:59
Hi again.
Is there an option to configure the sorting parameter in the cms cataloglist module?
I think (maybe i'm wrong) that it is sorting always by relevance, even if I configure client/html/catalog/lists/sort to be "-ctime". This configuration changes the default sorting method on lists, but not on cataloglists.
Thanks!
Re: Sorting products in cms cataloglist
Post by aimeos » 10 Mar 2023, 09:42
It's not yet possible to configure sorting for the cataloglist elements in the CMS.
You could add it here:
- https://github.com/aimeos/ai-cms-grapes ... #L576-L595
- https://github.com/aimeos/ai-cms-grapes ... #L108-L115
If you create a PR, we will merge it into the core :-)
