Add link "to checkout" in mini basket
heural
Post by heural » 04 Apr 2023, 12:27
Hi Aimeos-Team,
how can I add a link in mini-basket "to checkout" to go directly to the checkout pages.
I overwrite the template for the mini basket:
 <div class="to-checkout">
                <a class="btn btn-primary" href="<?= $enc->attr( $this->link( 'client/html/checkout/standard/url' ) ) ?>">
                    <?= $enc->html( $this->translate( 'client', 'Checkout' ), $enc::TRUST ) ?>
                </a>
            </div>
but the link in href is "relative" to the page instead of "/checkout?ai%5Baction%5D=standard&ai%5Bcontroller%5D=Checkout"
It seems that "client/html/checkout/standard/url" only return "?ai%5Baction%5D=standard&ai%5Bcontroller%5D=Checkout"
Thank you!
Ralf
Thanks a lot!
Re: Add link "to checkout" in mini basket
Post by aimeos » 07 Apr 2023, 08:15
Add "absoluteUri" as third parameter to the link view helper call:
$this->link( 'client/html/checkout/standard/url', [], ['absoluteUri' => 1] )
Documentation: https://aimeos.org/docs/latest/infrastr ... view/#link
heural
Post by heural » 17 Apr 2023, 07:21
Documentation...it could be so easy
Thank you!
Thanks a lot!
