Questions about deployment
fate0079
Post by fate0079 » 14 May 2023, 02:00
After the deployment is completed according to the tutorial, I can only access some resources on the home page. Other routes return 404. Why?
Re: Questions about deployment
Post by aimeos » 14 May 2023, 09:49
Any additional information? Aimeos version? Which package/distributiion? Any errors before?
fate0079
Post by fate0079 » 14 May 2023, 11:47
wget https://getcomposer.org/download/latest ... poser.phar -O composer
php composer create-project aimeos/aimeos myshop
I pulled the source code directly according to this command, but it seems that I do see resource files such as admin in my virtual machine folder
fate0079
Post by fate0079 » 14 May 2023, 11:49
http://64.176.185.64/
check it,
php 8.0.2
centos 8
Post by aimeos » 14 May 2023, 12:23
PHP 8.0.2 isn't supported because of bugs in the PHP interpreter. You need at least PHP 8.0.11 and that doesn't seem to be enforced by composer when installing the distribution even if it's added in the composer.json as requirement.
fate0079
Post by fate0079 » 14 May 2023, 12:46
I have upgraded the php version, still the same error. there is no admin in my resource file, so it cannot be found?
Post by aimeos » 16 May 2023, 06:41
What do you mean? What is the "resource" file?
Can you please install the Aimeos distribution again? Due to the buggy PHP version it's likely that it's not installed correctly.
