Custom attributes not updating
DamanMokha
Post by DamanMokha » 21 May 2023, 13:37
I am using the headless version of Aimeos(2023.04.*) and have created custom attributes, including the ability to set a custom price for a product. When adding a product to the cart, the custom price and other custom attributes such as weight are successfully saved. However, when updating the cart, only the quantity is being updated and the custom attributes remain unchanged.
I am using the following update API endpoint:
 /jsonapi/basket?id=default&&related=product&relatedid=0
with the PATCH method. The following is the body of the request:
    "data": {
        "attributes": {
            "quantity": 1,
            "custom": {
                "7": "12.22",
                "29": "12"
7th id is for the custom price, it's working fine while adding but not updating, can you please help me out.
Re: Custom attributes not updating
Post by aimeos » 24 May 2023, 09:04
You can only change the quantity using the PATCH method for the basket/product endpoint:
https://aimeos.org/docs/latest/frontend ... t-products
If you want to change the configurable or custom attributes of a product in the basket, you have to remove the product from the basket first and add it again afterwards using the new configurable or custom attributes.
