route aimeos_shop_checkout throwing ArgumentCountError
sheerazabbas
Post by sheerazabbas » 31 May 2023, 05:29
Hi Dear,
I just enabled the paypal express and all seems working fine, after the 5th ( summary ) step of checkout, once clicked at "Buy now" button it is throwing ArgumentCountError (252 arguments are required, 2 given) from Middleware/SetLocale.php
please check attach error log images.
any kind of help will be highly appreciated. thanks.
versions
versions
Screenshot 2023-05-31 at 10.27.00 AM.png (69.34 KiB) Viewed 9556 times
error-log
error-log
Screenshot 2023-05-31 at 10.26.48 AM.png (120.17 KiB) Viewed 9556 times
Re: route aimeos_shop_checkout throwing ArgumentCountError
Post by aimeos » 31 May 2023, 07:32
setLocale() is not the problem, click on "Expand all vendor frames" to see the last 2-3 entries
sheerazabbas
Post by sheerazabbas » 31 May 2023, 14:31
here is "Expanded all vendor frames" with some last logs
expanded logs
expanded logs
Screenshot 2023-05-31 at 7.29.17 PM 2.png (86.48 KiB) Viewed 9540 times
Post by aimeos » 31 May 2023, 14:37
Check the "paypalexpress.PaypalUrl" value in Setup > Services > PayPal in the admin backend. It seems like it's value is wrong and you can remove the complete line so the default value will be used again.
sheerazabbas
Post by sheerazabbas » 01 Jun 2023, 03:46
Dear,
Thanks for support and replying.
The value for the "paypalexpress.PaypalUrl" that I was using was "https://www.sandbox.paypal.com/webscr&c ... ken=%251$s"
as I was integrating according to the sandbox level configuration.
deleted this line and got the default value as "https://www.paypal.com/webscr&cmd=_expr ... token=%1$s"
and it is working now.
all other values like
- paypalexpress.ApiEndpoint
- paypalexpress.ApiSignature
- paypalexpress.ApiUsername
are according to sandbox environment.
