/shop make list view default view
samvara
Post by samvara » 24 Jun 2023, 09:29
Hi!
Is there a configuration option to make list view the default view on /shop
Thanks,
samvara.
Re: /shop make list view default view
Post by aimeos » 26 Jun 2023, 07:18
The simplest way is to add a redirect to your ./routes/web.php file:
    Route::get('/', function () {
        return redirect(airoute('aimeos_shop_list'));
The better option is to add the list component to the home page in ./config/shop.php:
	'page' => [
		// Docs: https://aimeos.org/docs/latest/laravel/extend/#adapt-pages
		'catalog-home' => ['locale/select','basket/mini','catalog/filter','catalog/tree','catalog/search','catalog/price','catalog/supplier','catalog/attribute','catalog/session','catalog/stage','catalog/lists'  ],
Additionally, you have to overwrite the catalog list view template using:
mkdir -p resources/views/vendor/shop/catalog/
cp ./vendor/aimeos/aimeos-laravel/views/catalog/list.blade.php resources/views/vendor/shop/catalog/home.blade.php
