Import Stocks for products using xml import
lockhart97
Post by lockhart97 » 14 Sep 2023, 11:40
Laravel framework version: 10.18.0
Aimeos Laravel version: 2023.07
PHP Version: 8.2.8
Environment: Linux
It is documented how to add stocks for CSV import but I cannot find it in XML import.
How to import products with stock data when using XML import?
Re: Import Stocks for products using xml import
Post by aimeos » 15 Sep 2023, 05:46
Stock import is only available via CSV, not via XML
