PropertyAdd data missing in basket
shainanand
After I enabled the PropertyAdd plugin, how can I access the product properties within the basket? Right now if I print the basket data, there is no property.
- Image 20.png (35.63 KiB) Viewed 4177 times
- Image 19.png (15.85 KiB) Viewed 4177 times
Re: PropertyAdd data missing in basket
The properties (if there are any for that product) will be available in the "attributes" array of the products. Keep in mind that the configuration has to be added before you put anything into the basket.
