To which function does this API goes to?
shainanand
Post by shainanand » 19 Nov 2023, 03:09
I want to increase the limit of values shown inside dropdown in admin->product->characteristics->attribute dropown. But not sure where to update the limit/slice.
I have a hard time understanding the codebase for this API requests from admin->product->characteristics->attribute dropown
http://npk.test/admin/default/jsonadm/attribute/type?locale=en&filter%5B%26%26%5D%5B0%5D%5B%7C%7C%5D%5B0%5D%5B%3D~%5D%5Battribute.type.code%5D=&filter%5B%26%26%5D%5B1%5D%5B%3E%5D%5Battribute.type.status%5D=0&sort=attribute.type.label
I thought it would be vendor\aimeos\ai-admin-jsonadm\src\Admin\JsonAdm\Attribute\Standard.php. But seems like it isn't. Any help would be appreciated. Also any other way to increase the limit?
Re: To which function does this API goes to?
Post by aimeos » 20 Nov 2023, 17:07
This endpoint uses the JsonAdm Standard class because there's no specific implementation for "attribute/type":
https://github.com/aimeos/ai-admin-json ... d.php#L541
But the size of the returned result set should be passed in the JS code.
Which Aimeos version are you using? In the latest verison, the JsonAdm API isn't used any more and the GraphQL API is used instead.
