Implementing an admin panel
jafo66
Post by jafo66 » 25 Mar 2024, 03:43
With the context of my other posts, I've been following the docs to the best of my ability. I was able to successfully implement a menu item.
When I click on the menu item it went to: [url]http://localhost:8000/admin/default/jqadm/search/season?locale=en[/url] and then I got an error that ./src/Season/Standard.php doesn't exist. I can't find a reference or example for what that file does. I did create the file and was able to output some HTML.
Question: what is supposed to be in that file OR how do I get it (via: redirect or inline) to the list.php in ./templates/admin/jqadm/season/list.php?
Re: Implementing an admin panel
Post by aimeos » 27 Mar 2024, 09:59
The file location mentioned in the error isn't within the expected directory structure. There seems to be something wrong in your setup.
jafo66
Post by jafo66 » 28 Mar 2024, 14:38
You are correct, I had not configured my extension properly. Once that was resolved, it is working properly now. (Thanks to Norbert at Aimeos)
