Importing stock deletes product ref items like images and text
kdim95
Post by kdim95 » 18 Apr 2024, 03:02
Laravel framework version: 11.3.1
Aimeos Laravel version: 2023.10.8
PHP Version: 8.2.17
Environment: Linux
aimeoscom/ai-elastic: 2023.04.*
Text and images disappear when importing stock.
I think the domains for the products are not selected when updating them.
Is there a config where I need to add the product domains used when importing stock?
Best regards
Re: Importing stock deletes product ref items like images and text
Post by aimeos » 19 Apr 2024, 14:57
You are right, for document-oriented storages, only the basic product data has been saved when updating the instock value. This has been fixed in this commit: https://github.com/aimeos/ai-controller ... 814b278469
You can get the fixed version until a new release is tagged by using:
composer req aimeos/ai-controller-jobs:2023.10.x-dev
kdim95
Post by kdim95 » 23 Apr 2024, 11:31
Thank you, this seems to have solved it
