Uncaught TYPO3 Exception
joakim
Post by joakim » 03 May 2016, 08:12
When I set 'SYS/displayErrors' => '1' to display all errors, I get Uncaught TYPO3 Exception when trying to use Aimeos.
Screenshot: http://prntscr.com/azorha
It seems it looks for manifest.php on the path ext/.gitignore/manifest.php when it only resides in ext/manifest.php
Re: Uncaught TYPO3 Exception
Post by aimeos » 03 May 2016, 08:32
Thanks for the screenshot!
It thinks ".gitignore" is a directory so I've added a check to test this before but I don't know if it will avoid the warning completely.
