Problem on adding product to basket
bar_on
Post by bar_on » 08 Aug 2024, 08:25
I have problem retrieving session from previous api calls. The get basket api call after adding product to basket returns empty basket.
I found that in local environment the response header of jsonapi changes after adding products.
basket api local header.png (97.94 KiB) Viewed 9065 times
jsonapi loca header.png (71.82 KiB) Viewed 9065 times
This does not happen in the official demo of aimeos.
jsonapi demo header.png (80.41 KiB) Viewed 9065 times
Version:
"aimeos/aimeos-laravel": "~2023.10",
"php": "^8.1.0",
Re: Problem on adding product to basket
Post by aimeos » 08 Aug 2024, 08:27
Make sure the same Laravel session cookie is sent along with each request to make.
