Stock is mising in admin
- AleksandarJovanovic
Php 8.2
Linux
Version 2024.10.
In the new version 2024.10, the stock option doesn't work when I select the product. I can't add stock, as the '+' is missing, unlike in previous versions. It appears in demo products, but once they are deleted, there is no way to add it again.
Attached is the image.
Kind regards
Linux
Version 2024.10.
Kind regards
- Screenshot from 2024-10-13 13-03-34.png (162.65 KiB) Viewed 32826 times
Re: Stock is mising in admin
Thanks for the hint! The problem has been fixed in aimeos/ai-admin-jqadm and a new release will be tagged tomorrow.
