Backend curiose overview
heural
Post by heural » 24 Oct 2024, 08:21
Hi Aimeos-Team,
we have a curiose overview in our production system now:
Orders are created before the Oct. 19. :o
In the protocol long queries are logged with > 1s:
Time: 1014.7659778595ms
Class: Aimeos\MShop\Order\Manager\Standard
SELECT "order.chour", count("val") AS "value"
FROM ...
Time: 1369.9569702148ms
SELECT
mord."id" AS "order.id", mord."channel" AS "order.channel",
mord."siteid" AS "order.siteid", mord."invoiceno" AS "order.invoiceno", ...
Time: 1056.0281276703ms
SELECT "order.currencyid", "order.cwday", sum("val") AS "value"
FROM (
SELECT mord."currencyid" AS "order.currencyid", mord."cwday" AS ...
Seems there is a a performance issue in our mysql-server or some indexes are not used?
Aimeos 2023.10.7
Typo3 12.4.20
Thanks a lot!
Re: Backend curiose overview
Post by aimeos » 24 Oct 2024, 08:58
Seems like you have a very high number of orders within one week and the counting stops at 10,000 records for performance reasons. Can you check which indexes would speed up the queries?
