How to fetch catalog media and text.
Jairus34
Post by Jairus34 » 28 Oct 2024, 12:11
Hi Aimeos,
I'm trying to fetch catalog media and text, but the include array in the response appears to be empty.
Is my query correct, or am I missing something? Here's the query I’m using:
http://localhost:8000/jsonapi/catalog?id=2&include=media,text
My goal is to include both media and text while fetching details for a specific catalog. One note: both media and text are set to the Estonian language. Do I need to add a query parameter for the language ID?
Re: How to fetch catalog media and text.
Post by aimeos » 28 Oct 2024, 13:33
Guess, you are using Laravel. If you need texts in a specific language, add "&locale=<two letter ISO language code>" to the URL, in your case it should be "&locale=et".
