How to add a list of services in the basket for the item
NeilM
Post by NeilM » 18 Nov 2024, 17:58
I have an item in the basket, I have added an attribute called service - however it only allows me to select one item. When I try to add another attribute of type service, it adds separate select box rather than a single select box with the 2 items
the setup of the attribute
setup wheel.png (134.51 KiB) Viewed 33360 times
The bucket with the single items in the select box
Re: How to add a list of services in the basket for the item
Post by aimeos » 19 Nov 2024, 16:01
Did you add both as configurable attributes to the product?
