Apply Discount in Checkout Total Amount?
- PaoloLegaspi
In the project I’m working on, we want to give customers a 5% discount if they add their national ID during registration or in their profile. I’ve already added the necessary attribute to the users table.
Now, I’m looking to implement this functionality in our checkout process using Aimeos. The goal is for the 5% discount to automatically apply to the order total/order.price for users who have provided their national ID.
Is there a specific part in the documentation or a guide that covers this type of customization? Any help or pointers would be greatly appreciated!
//Frontend view
Aimeos version: Aimeos Headless 2024.07.*
PHP version: 8.2
Environment: Mac
- Screenshot 2024-12-03 at 8.28.27 PM.png (53.85 KiB) Viewed 174988 times
- PaoloLegaspi
Re: Apply Discount in Checkout Total Amount?
I’m thinking of creating a Basket Plugin Provider to handle this. My idea is to dynamically set the customer’s discount percentage, check the authenticated user, and apply the calculated discount to the total product price in the basket.
Does this approach make sense? Is it possible to achieve this with a custom basket plugin in Aimeos?
Yes, makes sense and you need a basket plugin for that: https://aimeos.org/docs/latest/provider ... t-plugins/
The alternative would be a coupon provider but it's discount would be only applied if the customer enters a coupon code.
- PaoloLegaspi
Thanks for getting back to me!
Do you know of any examples or references I could check out? Especially something that shows how to recalculate the basket total with the discount.
There's no basket plugin yet that suits as an example for what you need to do but use these steps:
1.) Create a discount product like done here: https://github.com/aimeos/aimeos-core/b ... #L224-L238
2.) Add the discount product to the order using addProduct()
3.) Check if the event occurs again and update the discount product in that case
- PaoloLegaspi
Thank you for the guides! I followed the steps you provided and used the percentage rebate from the coupon provider to set up percentage discounts. It works great and adds the discount product to the basket.
However, I ran into an issue: when a product in the basket is about to go out of stock, and the customer adds more quantity (by clicking the plus button), it shows a "product out of stock" message but still adds the discount product and calculates its price. Ideally, this shouldn’t happen. Also, could you let me know if my implementation is correct and follows Aimeos standards?
//ClientDiscount Basket Plugin
I am using Aimeos with frontend to show the issue screenshot
public function register(\Aimeos\MShop\Order\Item\Iface $p): \Aimeos\MShop\Plugin\Provider\Iface
$plugin = $this->object();
$p->attach($plugin, 'addProduct.after');
$p->attach($plugin, 'deleteProduct.after');
$p->attach($plugin, 'setProducts.after');
$p->attach($plugin, 'check.before');
return $plugin;
public function update(\Aimeos\MShop\Order\Item\Iface $order, string $action, $value = null)
$percent = (float) $this->getConfigValue('rebate.percent');
$prodcode = $this->getConfigValue('rebate.productcode');
$user = $this->context()->user();
if ($percent == 0 || $prodcode === null || empty($user) || $user->getPersonalCode() === null) {
return $this;
$products = $order->getProducts();
if (count($products) === 0) {
$this->removeDiscountProduct($order, $prodcode);
return $this;
$price = $this->calcPrice($order);
$rebate = $this->round(($price->getValue() + $price->getCosts() + $price->getRebate()) * $percent / 100);
if ($rebate > 0) {
$discountProduct = $this->createDiscountProduct($prodcode, 1, 0, $rebate);
$order->addProduct($discountProduct);
return $this;
public function createDiscountProduct(string $prodcode, float $quantity = 1, float $price = 0, float $rebate = 0): \Aimeos\MShop\Order\Item\Product\Iface
$productManager = \Aimeos\MShop::create($this->context(), 'product');
$product = $productManager->find($prodcode, ['price']);
$priceManager = \Aimeos\MShop::create($this->context(), 'price');
$priceItem = $priceManager->create()->setValue(-$rebate)->setRebate($rebate);
return \Aimeos\MShop::create($this->context(), 'order/product')->create()
->copyFrom($product)
->setQuantity($quantity)
->setStockType( 'default' )
->setPrice($priceItem)
->setFlags(\Aimeos\MShop\Order\Item\Product\Base::FLAG_IMMUTABLE);
protected function calcPrice(\Aimeos\MShop\Order\Item\Iface $base): \Aimeos\MShop\Price\Item\Iface
$price = \Aimeos\MShop::create($this->context(), 'price')->create();
foreach ($base->getProducts() as $product) {
$price = $price->addItem($product->getPrice(), $product->getQuantity());
return $price;
protected function round(float $number): float
$prec = $this->getConfigValue('percent.precision', 2);
$value = $this->getConfigValue('percent.roundvalue', 0);
if ($value == 0) {
return round($number, $prec);
return round(round($number / $value) * $value, $prec);
protected function removeDiscountProduct(\Aimeos\MShop\Order\Item\Iface $order, string $prodcode): void
foreach ($products as $position => $product) {
if ($product->getProductCode() === $prodcode) {
$order->deleteProduct($position);
- Screenshot 2024-12-15 at 9.22.53 PM.png (161.28 KiB) Viewed 163583 times
Seems like your calculation in your code is wrong. Check the value of the price, costs and rebate you sum up
- PaoloLegaspi
Hello
I checked out the code, and it’s calculating the price correctly when a product and quantity are added. The issue seems to show up only when the product is down to its last stock. If the user clicks the "Add Quantity" (+) button at that point, it incorrectly adds up a price to the rebate product price. Interestingly, this only happens on the first click—if the button is clicked multiple times after that, it no longer affects the price. I also tested this with coupon discount products, and it looks like the rebate price calculation stops entirely once the product is out of stock.
- PaoloLegaspi
Hi, this is a continuation of my custom basket plugin to apply 5% discounts to orders for regular customers. The plugin checks if the user is authenticated as a regular customer and adds the discount through a rebate product. It works fine in most cases, but there’s an issue when customers pay using coupons or gift cards.
In those cases, the order total ends up being negative because it seems like the coupon and gift card calculations don’t account for the regular customer discount. Any ideas on how to fix this? Thanks!
Note: The regular customer discount is always applied first, before coupons and gift cards, if the user is a regular customer.
Basket Plugin Code
Screenshot
Basket Plugin Code
$p->attach($plugin, 'setCustomerId.after');
$p->attach( $plugin, 'addAddress.after' );
$p->attach( $plugin, 'setAddresses.after' );
$p->attach( $plugin, 'addCoupon.after' );
$p->attach( $plugin, 'deleteCoupon.after' );
return $plugin;
$personalCode = $user ? $user->get('national_id') : null;
if ($percent == 0 || $prodcode === null) {
return $this;
if (count($products) === 0 || empty($personalCode)) {
return $this;
if ($rebate > 0) {
$discountProduct = $this->createDiscountProduct($prodcode, $rebate);
return $this;
return $price;
public function createDiscountProduct(string $prodcode, float $rebate = 0, float $quantity = 1, string $stockType = 'default'): \Aimeos\MShop\Order\Item\Product\Iface
if (!$product) {
$msg = $this->context()->translate('mshop', 'Product with code "%1$s" not found');
throw new \Aimeos\MShop\Order\Exception(sprintf($msg, $prodcode));
->setStockType($stockType)
->setCustomerDiscounted(1)
if ($value == 0) {
You have to add your basket plugin after the coupon plugin in Setup > Plugins to change the order of execution.
