Export orders
Bollerx
Export orders
Post by Bollerx » 25 May 2016, 11:39
1. Is it possible to export somehow to .xml(or .csv) the orders? I can see the option Export, but i don't know how can be enabled.
2. How can i show on orders the category(subcatalog) name, i cant see an option for that, and it's necessary for our project.
Re: Export orders
Post by aimeos » 25 May 2016, 14:57
Bollerx wrote: 1. Is it possible to export somehow to .xml(or .csv) the orders? I can see the option Export, but i don't know how can be enabled.
The "Standard" delivery service provider can export orders in XML format and push them to a remote HTTP gateway. You have to configure it as delivery option (the naming of the option is up to you) and execute the order/service/delivery scheduler task. Maybe it's best to extend from this class so you can export to a file and adapt the XML if necessary.
Bollerx wrote: 2. How can i show on orders the category(subcatalog) name, i cant see an option for that, and it's necessary for our project.
That's a bit more difficult because there's an m:n relation between categories and products, so a product can be in several categories. You have two options:
- Pass the current category as attribute from the detail view to the basket
- During the export, look up the categories and add them to the order export
