Adding Product URL Segment in Basket Response
PaoloLegaspi
Post by PaoloLegaspi » 03 Jan 2025, 09:27
Hi there,
We’re currently working on our cart, specifically with basket product lists. Would it be possible to include just the basket product’s URL segment in the Basket Response JSON:API?
We need this because we’re using the product slug to redirect users back to the product details page. Would we need a basket/product decorator and a custom item Standard for it?
Thanks!
Aimeos version: Aimeos Headless 2024.10.*
PHP version: 8.2
Environment: Mac
Re: Adding Product URL Segment in Basket Response
Post by aimeos » 06 Jan 2025, 13:40
Unfortunately not. The basket is saved as serialized object in the DB and not in the mshop_order* tables where data can be added while retrieving them. The only option is to fetch the product data with the URL segment in a second request of the JSON:API.
