Issues with Toggle All and Delete Modal in Custom Admin Panel
PaoloLegaspi
Post by PaoloLegaspi » 09 Feb 2025, 15:23
Hey there,
I set up a custom panel in the admin with a custom domain, and for the most part, it's working great—creating, searching, and updating items all function as expected. However, I’ve run into a couple of issues:
1. The "toggle all" checkbox doesn’t actually toggle all the checkboxes in the columns.
Screenshot 2025-02-09 at 11.21.18 PM.png (175.32 KiB) Viewed 9538 times
2. When I try to delete an item, the modal that pops up doesn’t display the labels of the entry/entries being deleted.
Screenshot 2025-02-09 at 11.21.32 PM.png (189.26 KiB) Viewed 9538 times
Any ideas on how to fix these? Thanks in advance!
Re: Issues with Toggle All and Delete Modal in Custom Admin Panel
Post by aimeos » 10 Feb 2025, 17:00
Make sure "list-view" is part of the class list of the node and all data-* attributes are set correctly:
https://github.com/aimeos/ai-admin-jqad ... hp#L65-L69
