Is it possible to change stock view
Bollerx
Post by Bollerx » 27 May 2016, 13:53
Is it possible to change stock view from boxes to available product stock number?
Re: Is it possible to change stock view
Post by aimeos » 28 May 2016, 07:47
Replace the catalog stock template with your own implementation. There you can create the output you need.
https://github.com/aimeos/aimeos-core/b ... efault.php
Bollerx
Post by Bollerx » 30 May 2016, 12:39
Thank's, it's working great.
