Reordering components in a blade section
matmunn
Post by matmunn » 31 May 2016, 03:31
In the 'aimeos_stage' section I've noticed that a category image is displayed above the breadcrumb navigation, is it possible to change this?
I've gone hunting through the code and notice that this is is provided by $aibody['catalog/stage'] but I haven't been able to find a way to change the output of this section. Is it user modifiable without having to edit the vendor src?
Re: Reordering components in a blade section
Post by aimeos » 31 May 2016, 09:53
It's a category picture and you can change it in the admin interface (expert mode) in the category listed in the "Catalog" tab.
matmunn
Post by matmunn » 31 May 2016, 22:51
Sorry to be unclear, I meant to change the order, like moving the category image beneath the breadcrumb navigation.
Post by aimeos » 01 Jun 2016, 07:32
Sure, you can change the order via configuration:
https://aimeos.org/docs/Configuration/C ... d/subparts
