Is it possible to create an order in the admin panel?
DNK
Post by DNK » 11 Mar 2025, 10:46
There is a task to create an order for a client. What could be such a solution?
Aimeos 2024.10.3 + Laravel 11, PHP 8.2, MySql8.0, Nginx, Ubuntu 22.04.5 LTS
Re: Is it possible to create an order in the admin panel?
Post by aimeos » 11 Mar 2025, 11:03
The short answer is no. If you have a concrete scenario where the options are limited then it's possible to implement a panel for creating orders.
DNK
Post by DNK » 11 Mar 2025, 12:07
Yes, I have a specific scenario.
I have to select a client from the existing ones and create an order for him.
When creating an order, I should have the same functionality as in the client part (shopping cart)
Post by aimeos » 11 Mar 2025, 12:19
DNK wrote: 11 Mar 2025, 12:07 When creating an order, I should have the same functionality as in the client part (shopping cart)
That may be difficult. The easier way is to create an order for the customer in the frontend.
