Error in Omnipay/Stripe
DNK
Post by DNK » 31 Mar 2025, 14:13
I got error in your extension:
  "error": {
    "message": "This PaymentIntent is configured to accept payment methods enabled in your Dashboard. Because some of these payment methods might redirect your customer off of your page, you must provide a `return_url`. If you don't want to accept redirect-based payment methods, set `automatic_payment_methods[enabled]` to `true` and `automatic_payment_methods[allow_redirects]` to `never` when creating Setup Intents and Payment Intents.",
    "payment_intent": {
      "id": "pi_XXXXXXXX",
      "object": "payment_intent",
      "amount": 100,
      "amount_capturable": 0,
      "amount_details": {
        "tip": {
      "amount_received": 0,
      "application": null,
      "application_fee_amount": null,
      "automatic_payment_methods": {
        "allow_redirects": "always",
        "enabled": true
      "canceled_at": null,
      "cancellation_reason": null,
      "capture_method": "automatic",
      "client_secret": "pi_3R**********************_******_*********************DlD2",
      "confirmation_method": "manual",
      "created": 1743016046,
      "currency": "eur",
      "customer": "cus_S11LPwqx9vnxI6",
      "description": "Order 60",
      "invoice": null,
      "last_payment_error": null,
      "latest_charge": null,
      "livemode": true,
      "metadata": {
      "next_action": null,
      "on_behalf_of": null,
      "payment_method": "pm_XXXXXX",
      "payment_method_configuration_details": {
        "id": "pmc_XXXXXXXX",
        "parent": null
      "payment_method_options": {
        "card": {
          "installments": null,
          "mandate_options": null,
          "network": null,
          "request_three_d_secure": "automatic"
        "link": {
          "persistent_token": null
      "payment_method_types": [
        "card",
        "link"
      "processing": null,
      "receipt_email": null,
      "review": null,
      "setup_future_usage": "off_session",
      "shipping": null,
      "source": null,
      "statement_descriptor": null,
      "statement_descriptor_suffix": null,
      "status": "requires_confirmation",
      "transfer_data": null,
      "transfer_group": "ORDER-60"
    "request_log_url": "https://dashboard.stripe.com/logs/req_XXXXXXX?t=1743016091",
    "type": "invalid_request_error"
Aimeos 2024.10.3 + Laravel 11, PHP 8.2, MySql8.0, Nginx, Ubuntu 22.04.5 LTS
DNK
Re: Error in Omnipay/Stripe
Post by DNK » 01 Apr 2025, 16:12
As an addendum. When entering the card number and after clicking the "Pay now" button, I am redirected to the bank page, where I have to confirm the payment. After I have confirmed, I am redirected back to my Aimeos store, but with an error
However, when I pay with another card, I am not redirected anywhere.
Therefore, I want to report a critical error in your application! And I urgently ask for help!
The error is related to the fact that you have not set up payments with redirection!
For testing this scenario use these test cards - https://docs.stripe.com/testing#3d-secu ... enge-flows
DNK
Post by DNK » 02 Apr 2025, 06:38
I received a response from Stripe about this error.
Hi there,
Upon reviewing the logs, I noticed that the Payment Intent was initially created with confirm: true in the request req_knv3MUhtnrKWA7 [0]. This automatically confirmed the Payment Intent and moved its status to requires_action. In such cases, the next step would be to use stripe.handleNextAction [1] to manage any additional actions required, such as 3D Secure authentication.
Could you share why you attempted to confirm the Payment Intent again in req_QLRNHIiGAiss3d [2]. When reconfirming a Payment Intent, it's necessary to submit both a new payment method and a return URL. This could explain why you're receiving an error about the missing return_url.
To resolve this issue, you have two options:
If you intended to create and confirm the Payment Intent in one step, simply use stripe.handleNextAction [1] after the initial creation with confirm: true.
If you need to confirm the Payment Intent separately, ensure you're providing both a new payment method and a return URL in the confirmation request.
Their response suggests that your omnipay/stripe plugin is not configured correctly. Please advise where I need to adjust the code!
Post by aimeos » 02 Apr 2025, 09:09
Guess, the problem is related to the "createtoken: yes" option in your Stripe configuration in the Setup > Services panel of the admin backend. Can you check if the problem vanishes if you change it to "no"?
DNK
Post by DNK » 02 Apr 2025, 09:25
No, it didn't solve the problem.
I found a solution. When confirming a payment, your plugin makes a request without specifying the return_url. This is a mandatory parameter.
It needs to be added after this line in this file
https://github.com/aimeoscom/ai-payment ... e.php#L238
As soon as I forked your plugin and added the line there
$response = $this->getProvider()->confirm( [
'paymentIntentReference' => $this->getOrderData( $order, 'Reference' ),
'return_url' => config('app.url') . '/shop/confirm/stripe',
] )->send();
Then the payment was immediately successful!
By the way, https://github.com/thephpleague/omnipay-stripe says that return_url is required:
Post by aimeos » 04 Apr 2025, 16:07
Great! Can you make a pull request so we can merge your fix into the ai-payments extension?
Post by aimeos » 08 Apr 2025, 10:30
The return URL has been added to the Stripe payment service provider now.
donnnnar
Post by donnnnar » 16 Apr 2025, 06:57
We're encountering another issue with the return_url parameter. On the Checkout-Confirm page (action=confirm&code=stripe&controller=Checkout), the return_url is empty, which leads to an error. According to DNK, the return_url must be set for Stripe.
Steps to reproduce:
- Place an order and proceed to the checkout payment page
- Enter credit card information
- Complete the payment successfully via Stripe
- After redirection, land on the confirmation page
- The confirmation page calls our custom checkout confirm decorator
- The custom decorator executes $this->client()->init(); on the first line
- That line triggers Stripe->updateSync(), where the config value for the payment success URL is empty
- It seems there should be a default value for the payment success URL, or it should never be empty to begin with.
Relevant code:
File: vendor/aimeos/ai-payments/src/MShop/Service/Provider/Payment/Stripe.php (starting at line 237)
// @todo: $default variable must be set
    'return_url' => $this->getConfigValue( ['payment.url-success'], $default )
] )->send();
Best regards,
Steve
Edit:
I changed the example
    'return_url' => $this->getConfigValue( 'payment.url-success', $default )
to
Post by aimeos » 16 Apr 2025, 07:26
donnnnar wrote: 16 Apr 2025, 06:57 File: vendor/aimeos/ai-payments/src/MShop/Service/Provider/Payment/Stripe.php (starting at line 237)
] )->send();
Does it work if you replace "payment.url-success" by "payment.url-self"?
donnnnar
Post by donnnnar » 16 Apr 2025, 07:57
No,
$this->getConfigValue( ['payment.url-self'] )
also returns null.
