Frontend changes not showing
dugz1611
Post by dugz1611 » 09 Jun 2025, 15:09
Good Day
I made minor customizations to my frontend within my own shop extension in C:\Users\dugz1\myshop\packages\getpriceza\views\base.blade.php, I made changes to the labels on the footer and also some text changes and links, however when I refresh localhost:8000 it still shows the default Aimeos which is in this view - C:\Users\dugz1\myshop\vendor\aimeos\aimeos-laravel\views\base.blade.php, please assist in pointing me in the right direction As I am sure that I should be able to overwrite using my own shop ext, kind regards.
Windows
Aimeos Version - ~2023.10
PhP Version - 8.1.12
Re: Frontend changes not showing
Post by aimeos » 10 Jun 2025, 07:00
To overwrite the base.blade.php template of the Aimeos extension, you have to place your copy in vendor\aimeos\aimeos-laravel\views\vendor\shop\base.blade.php. See: https://aimeos.org/docs/latest/laravel/ ... -templates
dugz1611
Post by dugz1611 » 12 Jun 2025, 07:51
Good Day
See in the image my screenshot no /shop folder exists when I have installed, should I create my own shop folder with my base.blade.php inside? The default base.blade.php exists here: C:\Users\dugz1\myshop\vendor\aimeos\aimeos-laravel\views\base.blade.php
Screenshot of issue
Screenshot of issue
dugz1611
Post by dugz1611 » 12 Jun 2025, 08:23
Also I have done changes to my copy here C:\Users\dugz1\myshop\vendor\aimeos\aimeos-laravel\views\shop\base.blade.php and ran php artisan view:clear to clear the cache but still loads the default Aimeos template
dugz1611
Post by dugz1611 » 12 Jun 2025, 08:53
Ahh I realised my issue and pasted my template here C:\Users\dugz1\myshop\resources\views\vendor it is loading correctly now!
