Dont see Type in SEO on CMS pages
AleksandarJovanovic
Post by AleksandarJovanovic » 29 Sep 2025, 21:21
Php 8.3
Linux
Aimeos 2025.07
Hello Aimeos Team,
I'm having a problem in the CMS where, under the SEO option, when I try to add any "Type", the list is empty, even though I haven't changed or deleted anything.
Everything is fine on the product (page) and I can add text for the Meta (tags) etc.
Image is attached.
Thank you in advance,
Alex
Screenshot from 2025-09-29 23-11-22.png (85.29 KiB) Viewed 73234 times
Re: Dont see Type in SEO on CMS pages
Post by aimeos » 30 Sep 2025, 16:45
Seems like the types are missing in the database. You execute this command to update your database if something is missing for any reason:
php artisan aimeos:setup
AleksandarJovanovic
Post by AleksandarJovanovic » 30 Sep 2025, 17:55
I ran the command but the same problem persists. I installed two more clean Aimeos installations on the latest version, but these fields are still missing. :(
AleksandarJovanovic
Post by AleksandarJovanovic » 30 Sep 2025, 20:02
When i go save and close i have this error
Aimeos\MShop\Text\Item\Standard::setType(): Argument #1 ($type) must be of type string, null given, called in /media/pascual/D/Projekti/aimeos_dev/myshop/vendor/aimeos/aimeos-core/src/MShop/Text/Item/Standard.php on line 189Can you replicate the same version i think its bug in this version.
I try
But no succes. I install new instalation and make again migration but nothing.
Alex
Post by aimeos » 02 Oct 2025, 10:15
There was a problem fetching the correct types for the views.
It's fixed now in aimeos/ai-cms-grapesjs dev-master and 2025.07.2
AleksandarJovanovic
Post by AleksandarJovanovic » 02 Oct 2025, 13:01
Yes, everything is fine now, I tested it :) Thank you very much.
