PANEL DE ADMINISTRACIÓN NO ME ABRE, SOLO SHOP
ErickMurillo
Post by ErickMurillo » 17 Nov 2025, 01:07
Buenas tardes instale aimeos 2025 con laravel 12, php 8.3 en ubuntu server 24.04 lts sin embargo en la ruta shop me abre correctamente pero la ruta /admin me redirecciona a laravel http://192.168.88.9:8000/login?locale=en ingreso el super usurio y solo me deja en laravel/dashboard estoy usando puerto 8000 les dejo captura ojala puedan ayudarme
Re: PANEL DE ADMINISTRACIÓN NO ME ABRE, SOLO SHOP
Post by aimeos » 17 Nov 2025, 09:16
Translation:
Good afternoon, I installed Aimeos 2025 with Laravel 12, PHP 8.3 on Ubuntu Server 24.04 LTS. However, the shop path opens correctly, but the /admin path redirects me to Laravel http://192.168.88.9:8000/login?locale=en. I enter the super user and it only leaves me in Laravel/dashboard. I am using port 8000. I am sending you a screenshot. I hope you can help me.
Does http://192.168.88.9:8000/admin show the Aimeos dashboard?
ErickMurillo
Post by ErickMurillo » 17 Nov 2025, 18:58
Hola la dirección http://192.168.88.9:8000/admin me muestra el panel de laravel breeze y cuando ingreso con el supert usurio queda en laravel y no me abre para nada el panel de administardor de aimeos, solo el SHOP me abre
Post by aimeos » 18 Nov 2025, 09:21
ErickMurillo wrote: 17 Nov 2025, 18:58 Hello, the address http://192.168.88.9:8000/admin shows me the Laravel Breeze panel, and when I log in with the superuser, it stays in Laravel and does not open the Aimeos administrator panel at all, only the SHOP opens.
Did you install the Aimeos distribution or the Aimeos Laravel package? In the later case, please check if you've set up the authentication and authorization correctly like described here:
https://github.com/aimeos/aimeos-larave ... entication
