Basket doesn't recalculate volume price when adding items
columbo
Post by columbo » 01 Sep 2026, 19:59
Steps to reproduce:
Create a product with graduated/volume prices, e.g.:
1–8 pcs → 2,90
9+ pcs → 2,20
Add 8 pieces to the basket -> price correctly shows 2,90/pc
Add 1 more piece of the same product on the category or detail page (not by editing the quantity field on the basket page).
=> Standard basket and mini basket now shows quantity 9, but the unit price is still 2,90 instead of 2,20.
When adding products to the shopping cart, there is no check to see if a new volume price has been reached and whether the price needs to be updated
(If 9 or more products are added at once, the correct price is applied immediately.)
Thank you!
Re: Basket doesn't recalculate volume price when adding items
Post by aimeos » 02 Sep 2026, 11:42
Thank you for your report!
The problem has been fixed in dev-master, 2026.04.x-dev, 2025.10.x-dev, 2024.10.x-dev, and 2023.10.x-dev.
Can you confirm that it works for you too?
columbo
Post by columbo » 02 Sep 2026, 18:51
yes, it works now
ProductPrice Plugin enabled:
Since we also have the aimeos extension for "Customer or Customer Group Specific Items" in place, will the ProductPrice Plugin affect the group or custom prices in any way? Any side effects here?
Thank you!
Post by aimeos » 03 Sep 2026, 07:12
The change should also work with custom prices for different customer groups but can you check that to be sure?
